A few little niggles with my V6!
Been poking around it today after getting it last night and a couple of things which are bugging me.
1: ECU and ABS light comes on now and again, Everything seems to be running fine etc and just had new discs and pads all round.
2: Elec sunroof is not working, Fuse is fine and the windows work but sunroof doesn't do a thing.
3: Traction Control button doesn't do anything, surely it should turn it on and off but nothing at all.
Cheers :thumb:
Si
Cheers :thumb:
Si
simonV6
<!--QuoteBegin-simonV6+--><div class='quotetop'>(simonV6)</div><div class='quotemain'><!--QuoteEBegin-->1: ECU and ABS light comes on now and again, Everything seems to be running fine etc and just had new discs and pads all round.<!--QuoteEnd--></div><!--QuoteEEnd-->
Do they come on together? if they do it might be a bodge behind the clocks to look like sommits working when its not
Rusty_CallyT
<!--QuoteBegin-Rusty_CallyT+--><div class='quotetop'>(Rusty_CallyT)</div><div class='quotemain'><!--QuoteEBegin-->Do they come on together? if they do it might be a bodge behind the clocks to look like sommits working when its not<!--QuoteEnd--></div><!--QuoteEEnd-->
No they come on whenever they feel like it, sometimes together sometimes just the1.
Just been out in it for an hour and none of them came on. :freak3:
simonV6
TC button turns the traction control off. To test if its still working without touching the button move the car away from a standing start as per traffic light gp. Bring the car to a stop press the button and try it again. If its working you will notice the difference. When you turn the ignition off it always resets to working.
Tim2001
