Trip computer - Switch problem
Hello
I have installed a trip computer in to my cally 16v Ecotec [img]/smile.gif[/img]
The computer is wired in to the dash board and seems to be working.
I am now trying to wire the switch in. I have read the guide on this site, and the information explains the the switch needs to be plugged in to a big long white block under the hand break next to where the electric windows are plugged in too.
I am unable to plug it in, because there is no wiring looms the other side of the block [img]/sad.gif[/img]
Did vaux cable tie that up too somewhere?.
James
James
calibra
styling products
yep, from memory, sorry Tattoman I didn't get time to take a photo with the 'rear' of it showing.
From what I can remember the switch plugs into the nasty yellow colour 'block' as it has the holes for the various switches (electric windows etc), so the electric window module switch is plugged in behind there as well.
I had to unscrew the handbrake console so I could lift it enough to get the switches in, tho you might be able to 'persuade' it without doing that..
Leigh
ARGH!!!! SCARY!
ah, yes. I'm pretty sure the carlton one has different connections, from what I read prior to gettting mine on ebay (there were a few comps without switches around at the time).
There's one on e-bay at the moment... <a href="http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=10404&item=2478825826&rd=1" target="_blank">HERE</a>
Does your existing one look like <a href="http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=10404&item=2478826335&rd=1" target="_blank">THIS ONE</a> ?
Leigh
