Pioneer AVD-W6200
Pioneer AVD-W6200
by Green Machine » Sun May 14, 2006 1:31 pm
Has anyone installed this screen before?
I am attempting the wiring myself, but am not sure where i shoul connect the Orange/White one? Does anyone know where i can fin the lighting switch terminal?
And is the ignition wire easily identifable?
Cheers Green Machine (Lee)
Green Machine
by dj_smurph » Mon May 15, 2006 7:28 am
lighting switch has gotta be for the facia lights so it can dim the screen at night
i earthed out the handbrake wire so the screen was on ll the time fitting a switch will make it semi-legal(so you can turn the screen off if you get pulled)
if you are using a standard wiring harness it should be easy to i dentify
dj_smurph
by Green Machine » Tue May 16, 2006 9:44 pm
Thanx DJ Smurf
Do you need to connect to the handbrake if the screens r in the back of the head rests?
If not what should i wire them to, a permanant positive feed?
Lee
Green Machine
by dj_smurph » Wed May 17, 2006 11:29 am
only if the screens are the front
the rears can be on all time
the wire that goes to the handbrake you just earth out
dj_smurph
