clocks
:iagree: Put one in mine was quite easy. Just got three wires to connect up to the clock +ve, -ve and ilumination if I remember right, and then two wires for the temperature sender which normally sits under the front bumper. I had to drill a hole behind the glovebox for my alarm and amp so ran temp sender wiring through there.
ross85
projectcalibra
