Advise needed on replacing a camshaft sensor (X20XEV)
Hi,
I possibly need to replace the camshaft sensor on an X20XEV. It currently has the older type sensor without the increased shielding. Can somebody confirm where the extra shielding wire needs to be crimped to? Also where does the other end of the wiring go, as I'd like to check that before replacing the whole sensor. Mine disappears accross the back of the engine to somewhere.
Johnnytenpints
dj_smurph
Right found a how2 guide on another site
<a href="http://vectra.no-ip.pl/~pepin/czujnik_walka/czujnik_walek_e.htm" target="_blank">http://vectra.no-ip.pl/~pepin/czujnik_walk...nik_walek_e.htm</a>
But I haven't got e-torx set so I'll have to get my m8 to do it for me and buy him a drink [img]/smile.gif[/img]
Johnnytenpints
