speedo help
speedo help
by ian » Tue May 30, 2006 9:34 pm
dam thing not working the rev counter ect is ok but not speedo where should i chex frist cheers guys....
ian
by TonyDTM » Tue May 30, 2006 10:13 pm
<!--QuoteBegin-ian+--><div class='quotetop'>(ian)</div><div class='quotemain'><!--QuoteEBegin-->dam thing not working the rev counter ect is ok but not speedo where should i chex frist cheers guys....<!--QuoteEnd--></div><!--QuoteEEnd-->
First check the easy end of the speedo drive cable where it goes into the gearbox. If it looks ok there then your going to be looking at the back of the instrument cluster.
If you need advice to remove the cluster just say and I can post full instructions of how to do it with minimum fuss.
Hopefully it will just be a case of the drive popping out of the back of the cluster and only needs clipping back in. Worst case is a new speedo cable. Pretty cheap to buy and not too long to fit. Just remove some trim and folow the old one [img]/smile.gif[/img]
TonyDTM
by ian » Tue May 30, 2006 11:03 pm
wheres the cabel on the gearbox do i need to get under the car ?
i know a bit about cars but nothing about speedos and gearboxs
your help would be great thanks ian
ian
by Tim2001 » Tue May 30, 2006 11:06 pm
Ian what year is your v6 as its probably electric rather than a cable as such.
Tim2001
by TonyDTM » Tue May 30, 2006 11:07 pm
without going out with a flashlight, iirc the cable is mounted on the top of the gearbox and at the back, but dont quote me as its 11 pm, and i have had a couple, its dark, its raining and i am tired. Pretty certain you dont have to get under the car to do any work on the speedo cable. You might be on ya knees in the footwell tho if you need to route a new one in. Theres not a lot of room to play in down there.
edit. Good point Tim, never even crossed my mind bout the electronic. Senders mounted on the side of the box right?
TonyDTM
by ian » Tue May 30, 2006 11:16 pm
its a 1996 n
ian
by Tim2001 » Tue May 30, 2006 11:18 pm
Will be an electric speedo then. Doubt its fuses if the rev counter is working. Have you had the speedo out for any reason ??
Tim2001
by ian » Tue May 30, 2006 11:22 pm
no m8 ive just got the car so not done anything yet al the lights work ect..
what do u surgest?
ian
by ian » Wed May 31, 2006 6:20 pm
tony any chance of that diyagram of the clocks look like the cable is in so it might be the spedo cabel at the back
ian
