Are all 8V ECU's the same?
by Leigh » Tue Jun 06, 2006 12:35 am
Nie easy one..
Does anyone know if all the 8V's (Calibra's at least with C20NE's) ECU's are/were the same,regardless of age, or did they change as the years went on? (like the ABS had a different unit later on.)
Just thought it might be handy to grab a spare ECU when they pop up from time to time if I can get one cheap, 'just in case'.
Leigh
by Rusty_CallyT » Tue Jun 06, 2006 1:34 am
got one here from an H reg you can buy.
pretty sure they are all the same, they may have changed over with the immobilisers on the later ones but cant be sure
Rusty_CallyT
by WillsToy » Tue Jun 06, 2006 10:21 am
Try looking at the top buzz site.
Not sure if all the same as the bosch tronic fuel injection may of changes in some of the later models to cope with cats/lambda systems
Will
WillsToy
by dicky » Tue Jun 06, 2006 10:24 am
All Calibra 8V's are Bosch M1.5 wereas the non cat/lambda ECU's where Bosch M4.1. They may be different though assome would have the transponder fitted.
dicky
by Leigh » Tue Jun 06, 2006 11:16 am
B*gger, forgot about the transponder. IIRC that was a later security upgrade wasn't it?
Not something I desperately need, more one of those long standing questions I've wondered about.
Thanks for the offer Rusty, totally skint at the moment tho, and probably looking at about £300 worth of parts and work to pass MOT [img]/sad.gif[/img] (new centre and frontpipe sections for exhaust,new rear brake compensator, welding handbrake mount, new handbrake shoes etc...grrr....and that's BEFORE it goes through MOT and they 'find' something else..)
Leigh
