Coolant Level Sensor Faulty
by hormonedmonkey » Sun Jul 02, 2006 2:44 am
It must be..... now is it just a case of replacing the cap with the 2 connectors going into it????
Does anyone have one?
I've trauled round the breakers and hunted on the net to no avail!
hormonedmonkey
by dj_smurph » Sun Jul 02, 2006 7:31 am
check the wires coming off as mine was playing up and all it was was the wires shorting it will be about 2-3 inches from the cap
dj_smurph
by ice man » Sun Jul 02, 2006 10:11 am
does the float move freely? Mine was stuck up causing it to not work.
ice man
by hormonedmonkey » Sun Jul 02, 2006 11:46 pm
everything appears to be fine, i just get the coolant level light on all the time
hormonedmonkey
by ice man » Mon Jul 03, 2006 12:07 am
If you take the connectors off the sensor does the light stay on?
If the float is down it makes the circuit, therefore unplugged the light should be off. if it's still on it's the wiring loom somewhere and not the switch.
ice man
by Naz » Mon Jul 03, 2006 8:19 am
Take the connector off and short them out together. the light should go out then. If it doesn't, this means there is a break in the wire somewhere. But if it does go ut, then this means the cap is fautly. I think the cap from Vauxh is abou £30?!!!
Naz
by Fostersice17 » Mon Jul 03, 2006 10:41 am
I had a problem with mine,it was the pillar sensor inside,was very dirty and was not making a contact,took it out cleaned it up and was fine after that.
Fostersice17
by ROG » Mon Jul 03, 2006 5:23 pm
<!--QuoteBegin-Fostersice17+--><div class='quotetop'>(Fostersice17)</div><div class='quotemain'><!--QuoteEBegin-->I had a problem with mine,it was the pillar sensor inside,was very dirty and was not making a contact,took it out cleaned it up and was fine after that.<!--QuoteEnd--></div><!--QuoteEEnd-->
when it looked like i had to get yet another last year, i did this as well and it worked, when it stops working, i just wash it under a tap moving the float round, let it dry, then put it back in for another 6 months till it does it again
ROG
by hormonedmonkey » Mon Jul 03, 2006 10:01 pm
well, i tried disconnecting it, didn't work so i'll give it a scrub
hormonedmonkey
by A_Venables » Mon Jul 03, 2006 10:09 pm
I had to replace mine on my 16v, in the end the dealer didnt have one for a Calibra but had one for a Carlton, this fitted, but was alot cheaper! Take ur old one and have a look at this option if you have to get another new one, cost me bout 15 quid instead of 30!
A_Venables
by ice man » Tue Jul 04, 2006 1:20 pm
<!--QuoteBegin-ice man+--><div class='quotetop'>(ice man)</div><div class='quotemain'><!--QuoteEBegin-->If you take the connectors off the sensor does the light stay on?
If the float is down it makes the circuit, therefore unplugged the light should be off. if it's still on it's the wiring loom somewhere and not the switch.<!--QuoteEnd--></div><!--QuoteEEnd-->
<!--QuoteBegin-Naz+--><div class='quotetop'>(Naz)</div><div class='quotemain'><!--QuoteEBegin-->Take the connector off and short them out together. the light should go out then. If it doesn't, this means there is a break in the wire somewhere. But if it does go ut, then this means the cap is fautly. I think the cap from Vauxh is abou £30?!!!
Cheers<!--QuoteEnd--></div><!--QuoteEEnd-->
Sorry - conflicting advice and i'm probably wrong - i'm crap on electrical problems LOL
ice man
by Fostersice17 » Tue Jul 04, 2006 1:48 pm
<!--QuoteBegin-ROG+--><div class='quotetop'>(ROG)</div><div class='quotemain'><!--QuoteEBegin-->when it looked like i had to get yet another last year, i did this as well and it worked, when it stops working, i just wash it under a tap moving the float round, let it dry, then put it back in for another 6 months till it does it again<!--QuoteEnd--></div><!--QuoteEEnd-->
It does work,i used a good limescale cleaner,think i used viakal or something like that,it really cleaned it up a lot.
Fostersice17
by Naz » Tue Jul 04, 2006 2:36 pm
Iceman >> Why is it conflicting advice?!!! WHat you say is that if you take the connectors off, the lights should stay on. Which is correct.
What I said was if you short the connector pins together, then the lights should go out. Which again is correct.
You see what I mean?!!!
Naz
by Naz » Tue Jul 04, 2006 2:38 pm
The way they work is that:
When coolant level is up to the right level, the float in the cap is floating so making a contact between the 2 pins, so the light stays out.
When the level falls below the level, then the float won't be floating anymore and won't make the contact, hence the light comes on.
This is how all the sensor wires are wired in the vauxhall. When they are ok( level ok) they make the circuit, and when the level is not ok, then they break the circuit.
Naz
by ice man » Tue Jul 04, 2006 11:44 pm
Yeah Naz - I got it backwards if you read my previous post again... I was guessing.
I.e. I was sorry for giving the wrong info... as in I said if you unplug it the light should go out (ooops)
ice man
