V6 coil pack query
V6 coil pack query
by Tim2001 » Mon Jul 03, 2006 8:15 pm
is there any sensor that would shut down part of the coil pack. Have had a few problems and diagnosed the coil pack as the problem as only running on 2 cylinders. New coil pack from vx today and still not running right as the two cylinders fed by the single coil at the end of the pack are receiving no spark. the leads are fine as have switched them round and checked that. There is just no spark coming from the coil pack.
Is there anything else to check before making the assumption that the coil pack is a duff one from vauxhall.
Tim2001
by Naz » Mon Jul 03, 2006 8:19 pm
Tim, what you have to do is to put a DMM on the pins of the coil pack. Or even better if you have a scope. This is to see:
1) you get a permanent 12v to the coil pack when the engine is not running.
2) When you crank or the engine runnig, you should see the voltage dropping to zero( spark) and then back up again.
If you get this, then the coil pack is faulty.
The only thing that sends the singal to the coil pack is the ECU and it gets its info from the crank sensor.
Hope this helps
Naz
by Fraz » Mon Jul 03, 2006 9:54 pm
Aha sounds like you have the same problem as Aldo had...have your tried the igntion amplifier
by Tim2001 » Mon Jul 03, 2006 11:07 pm
more details please fraz as am running out of time and patience.
Tim2001
by Naz » Mon Jul 03, 2006 11:13 pm
I don't think you can test the amplifier. You can just replace it.
HOWEVER I didn't realise you had a amplifier when you have a coil pack. I thought the coil pack had an amplifier in it already built?!!!
Naz
by Fraz » Mon Jul 03, 2006 11:18 pm
Not sure Tim TBH its Down on the passengers wing area..just at the back of the Battery...ALdo had same problem...got new coil pack plus leads and plugs...never made any diffrence...Took it to his auto sparky and they changed the amplifier ...car was perfect after that
by Fraz » Mon Jul 03, 2006 11:43 pm
would need to get a hold of Aldo as I am not exactly sure what It was they changed...they told Aldo a ignition Module down on the wing IIRC ...only thing I can think of is an amplifier
might be wrong and I am given you duff information..will call him tomorrow and get the part number of what it was they changed..cost was about £60 for the part
by nigescalli » Tue Jul 04, 2006 8:16 am
<!--QuoteBegin-Fraz+--><div class='quotetop'>(Fraz)</div><div class='quotemain'><!--QuoteEBegin-->would need to get a hold of Aldo as I am not exactly sure what It was they changed...they told Aldo a ignition Module down on the wing IIRC ...only thing I can think of is an amplifier
might be wrong and I am given you duff information..will call him tomorrow and get the part number of what it was they changed..cost was about £60 for the part<!--QuoteEnd--></div><!--QuoteEEnd-->fraz you are right sits on passenger wing just under pass bottle held down with 2 posi screws
nigescalli
Users browsing this forum: Bing [Bot] and 15 guests
