Front foglight relay????????
by cornishtaz » Wed Jul 26, 2006 9:29 am
Just a quickie anybody know where the front foglight relay is located.
cornishtaz
by Fraz » Wed Jul 26, 2006 1:20 pm
tried looking at this?
<a href="http://www.clubcalibra.net/forum/showthread.php?t=9540" target="_blank">http://www.clubcalibra.net/forum/showthread.php?t=9540</a>
by cornishtaz » Wed Jul 26, 2006 2:45 pm
Thanks for that, it's just the haynes manual shows a relay for cars fitted with front fogs
cornishtaz
by Fraz » Wed Jul 26, 2006 3:02 pm
never seen a relay as such only that link wire...guess its one of those way up behind the fuse box. found about 5 up there all hidden away
by cornishtaz » Wed Jul 26, 2006 3:08 pm
Haynes shows that there can either be a link wire or relay to control the rear fogs depending on model so that they only come on if fronts are switched on, link wire means that they'd work independant of fronts, but I could be wrong.
cornishtaz
by Fraz » Wed Jul 26, 2006 3:20 pm
no I have the link wire and they will only work if the front sde lights are on, back ones work that way as well
though they dont need the back on to work the front or vise versa
by cornishtaz » Wed Jul 26, 2006 3:26 pm
Mine is the same setup with the wire but looking at that link you posted up I pulled the relay you had down for rear fogs but they still worked.
cornishtaz
by cornishtaz » Wed Jul 26, 2006 6:22 pm
Thanks fraz for your help. For future ref the wire link is for rear fogs and the relay directly below it is front fogs.[img]/smile.gif[/img]
It ended up to be the switch even though it checked out ok on a risistance check and was operating ok.
cornishtaz
by Robs-se » Thu Jul 27, 2006 11:03 pm
i have one 30 amp fuse in the engine bay fuse box on the SE2. any ideas what this could be???
by RobbieV » Thu Jul 27, 2006 11:28 pm
<!--QuoteBegin-Robs-se+--><div class='quotetop'>(Robs-se)</div><div class='quotemain'><!--QuoteEBegin-->i have one 30 amp fuse in the engine bay fuse box on the SE2. any ideas what this could be???<!--QuoteEnd--></div><!--QuoteEEnd-->
Have a look here
<a href="http://www.v6calibra.com/docs/calibra_v6_fuses.htm" target="_blank">http://www.v6calibra.com/docs/calibra_v6_fuses.htm</a>
Pull the fuse and see what dont work [img]/smile.gif[/img]
by Fraz » Thu Jul 27, 2006 11:31 pm
main pwer fuse ..take that out and nothing works
by Robs-se » Thu Jul 27, 2006 11:49 pm
thanks Fraz + robbievRob
Users browsing this forum: Bing [Bot] and 15 guests
