V6 EML Annoying Now
V6 EML Annoying Now
What is wrong here?
Get Code 17 EML - Rear Knock.
Unbolt both knock sensors and swap them over. Reset ECU. Fault clear. After a few mins Idling, Fault 16.
Good proves knock sensor not wiring. Replace knock sensor. Reset ECU. Fault clear. Fault stays clear until you hit thr throttle. Fault 16 againg.
Can anyone help me please. Im getting annoyed now especially after having the cam HES probs all last week.
C411BRA
Yeah, thats whats confusing me. I checked the wiring and there didnt 'seem' to be anything wrong, so thats why I swapped fron to rear. I was thinking that this would prove the fault was in the sensor if the fault transferred to the front (17).
Thats exactly what it did. Got a new one from my local VX dealer, and fitted it and now fault 16 wont go away. Well id does while idling, after ecu reset, but soon as you pick up the revs to drive off, it fails again. But only on the front.
I'm thinking I may swap fron to back again to see if the fault transfers with the new sensor, I suppose it could be a dead new one.
Just in a bit of a quandry as to what else to do.
C411BRA
<!--QuoteBegin-marko+--><div class='quotetop'>(marko)</div><div class='quotemain'><!--QuoteEBegin-->same happened to me, code 16. found out that code 16 is infact the rear knock sensor and not the front one.<!--QuoteEnd--></div><!--QuoteEEnd-->How sure are you on this one as all the info I have found says its the front?
C411BRA
Unplug both sensors, reset ecu and start up. you should get code 16 and 17. plug front sensor back in and reset ecu, that should clear code 17 if working leaving code 16 logged. im quite sure code 16 is the rear knock sensor and 17 is the front one contrary to everything i have read also, i know how confusing it gets trying to work out witch is witch ive been there myself.
marko
For more info on knock sensors -
<a href="http://www.v6calibra.com/motonic/v6calibra_motronic_faultcodes.htm" target="_blank">http://www.v6calibra.com/motonic/v6calibra..._faultcodes.htm</a>
<a href="http://www.topbuzz.co.uk/info/knock_sensor/knock_sensor.htm" target="_blank">http://www.topbuzz.co.uk/info/knock_sensor/knock_sensor.htm</a>
<!--QuoteBegin-RobbieV+--><div class='quotetop'>(RobbieV)</div><div class='quotemain'><!--QuoteEBegin-->For more info on knock sensors -
<a href="http://www.topbuzz.co.uk/info/knock_sensor/knock_sensor.htm" target="_blank">http://www.topbuzz.co.uk/info/knock_sensor/knock_sensor.htm</a><!--QuoteEnd--></div><!--QuoteEEnd-->
<!--QuoteBegin-marko+--><div class='quotetop'>(marko)</div><div class='quotemain'><!--QuoteEBegin-->v6calibra.com also states code17 = rear, code 16 = front. This in my case was wrong and is infact the other way round.<!--QuoteEnd--></div><!--QuoteEEnd-->
Cheers guys, but I have already been down this route, and 16 is deefo the front one on mine. May be wiring then :frown: .
C411BRA
