Heater always live?
Heater always live?
My heater blower in the car has always worked fine on every setting but it even works when the engine is off - consequently the little bulb which appears to take its feed from the heater switch is always on and always blowing!
I'm sure this switch should be an ignition live and not permanent live.
I have taken everything apart and the wiring feed and switch mechanism all looks fine. Could it be the variable resistor by the blower itself has gone and consequently is not providing full resistance when the ignition is off - or is that a load of crap and somewhere I'm getting a short or bad earth?
cheers
Jusser
cheers
Jusser
jusser
