Fan Speed Switch
Fan Speed Switch
by Lounge Lizard » Mon Sep 04, 2006 9:16 am
Can anyone tell me what I need to fix so I have more than one speed on my fan switch. The fan only works on the second to last setting so its nearly flat out, very annoying!!
Lounge Lizard
by EY » Thu Sep 21, 2006 11:12 am
It will probably be a fuse, thats the best place to start if you havn't already. The fuse for the first stage fan is also the fuse for the air-con fan, it's a 30 amp fuse located in the engine bay fuse box.
Nice work on the door check arms.[img]/smile.gif[/img]
by RobbieV » Thu Sep 21, 2006 11:17 am
It could be the switch itself, had a similar problem once and was advised to change the switch and that fixed the problem [img]/smile.gif[/img]
by Twangy » Thu Sep 21, 2006 12:13 pm
Ceramic resistor under the windscreen wipers, most times attached to the motor itself, you can pick them up from the scrapper for a couple of quid.
Twangy
by EY » Thu Sep 21, 2006 12:18 pm
<!--QuoteBegin-Twangy+--><div class='quotetop'>(Twangy)</div><div class='quotemain'><!--QuoteEBegin-->Ceramic resistor under the windscreen wipers, most times attached to the motor itself, you can pick them up from the scrapper for a couple of quid.<!--QuoteEnd--></div><!--QuoteEEnd-->:lolabove: Anything small enough to fit in my toolbox is FREE.
by Twangy » Thu Sep 21, 2006 12:22 pm
<!--QuoteBegin-EY+--><div class='quotetop'>(EY)</div><div class='quotemain'><!--QuoteEBegin-->:lolabove: Anything small enough to fit in my toolbox is FREE.<!--QuoteEnd--></div><!--QuoteEEnd-->
Im lazy and let them get dirty.
Twangy
