Electric mirrors
Electric mirrors
by L337 calibra » Sun Sep 10, 2006 8:25 pm
Hi, new here
Ive just bought my first calibra and the electric mirrors dont work, well they do left and right but not up and down, ive changed the switch and its still the same, are there any areas where its prone to failing?
The fault is the same for both mirrors
And here she is, bought from ebay for £350 11 months mot 5 months tax
Ill take some more pics eventually and add them to the relevant section soon [img]/wink.gif[/img]
Andy
L337 calibra
by RobbieV » Sun Sep 10, 2006 8:28 pm
Hi and welcome [img]/smile.gif[/img]
as for your problem ive never heard of that one, sorry i cant help but iam sure someone will pop along with an answer for you.
by baby9bird » Sun Sep 10, 2006 9:15 pm
Our old cav was exactly the same give it a couple of days and they will start to work again. Maybe lack of use.Nice car and welcome.
baby9bird
by MJ » Sun Sep 10, 2006 9:24 pm
best colour good choice .... how often you need the leccy mirrors? once they're set they're set!
welcome o/
MJ
by L337 calibra » Sun Sep 10, 2006 9:44 pm
<!--QuoteBegin-KA25+--><div class='quotetop'>(KA25)</div><div class='quotemain'><!--QuoteEBegin-->best colour good choice .... how often you need the leccy mirrors? once they're set they're set!
welcome o/<!--QuoteEnd--></div><!--QuoteEEnd-->
Thanks
Yes ive set them manually so propably wont need to adjust again but its nice to know everything works.
Anyone know what colour the wires are for the up/down movement in the mirror plugs so I can input 12v so I know its not the mirrors at fault.
Is the mk3 cavs wiring the same because I can use the diagrams from the haynes manual.
Andy
L337 calibra
by Mark1 » Sun Sep 10, 2006 10:38 pm
Check that the mirrors are clipped in ok, top and bottom and left and right.
Club Treasurer
Club Treasurer
by EY » Sun Sep 10, 2006 10:43 pm
<!--QuoteBegin-Mark1+--><div class='quotetop'>(Mark1)</div><div class='quotemain'><!--QuoteEBegin-->Check that the mirrors are clipped in ok, top and bottom and left and right.<!--QuoteEnd--></div><!--QuoteEEnd-->Yeah check that the ball and socket behind the mirror is properly located and not broken, this could cause the symptoms you have.
by L337 calibra » Sun Sep 10, 2006 10:51 pm
Yes they are all clipped in, they werent before but still dont work, you cant even hear the buzz of the motor.
The connectors were a bit green when I took the mirrors off but I sprayed a bit of WD40 in both ends and no result [img]/sad.gif[/img]
Andy
L337 calibra
by GAZA62 » Mon Sep 11, 2006 9:02 pm
Used to have the same prob with my near side mirror after i washed the car would only go up and down but after a few days was OK managed to source a brand new one of E.bay only £38.
Try looking on there normally a few mirrors for sale.
I it was not for bad luck i'd have no luck at all
by Stupink » Mon Sep 11, 2006 9:19 pm
Sometimes the multiconnector where it goes from the car to the door can be at fault for that sort of problem, disconnect it, blow it out/dry with a compressor check for the green stuff and give it all a good clean/wd40 or whatever..
