mmmmmm oh and mmmmmmmm
engine management light
by andy1 » Thu Sep 21, 2006 6:33 pm
<!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo-->driving home to day and 1 of my dash lights flicked its on the top row on the left second in from the left (acording to the picture by ROBBIE V is the one with warter level and rear brake bulb) aleast i think that was the one that flicked as it was so quick im not to sure, but as it did flicker the car died for a split second like a miss fire or a glitch, then the light flicked again but still can not see wich one and the car done the same again, (i was doing around 55mph and climbing, <!--sizec--></span><!--/sizec-->
<!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo-->one other point i must make is since i have joind the forum i seem to be having more problems why lol!<!--sizec--></span><!--/sizec-->
andy1
by andy1 » Thu Sep 21, 2006 11:09 pm
any shed some light on this
andy1
by EY » Thu Sep 21, 2006 11:13 pm
Not much info there to go on mate. Wait for it to do it again, and commit the warning light to memory :icon_mrgr
by DeepSnoozer » Fri Sep 22, 2006 12:08 am
Paz, the calibras have very week grounds meaning that the negatives also called gnd's might get corroded and cause severla electrical problems like those
I Would sugest attaching a cable from the block of the engine to the chassis, and see if it works
DeepSnoozer
by wilkybar-kid » Fri Sep 22, 2006 12:28 am
<!--QuoteBegin-paz4919+--><div class='quotetop'>(paz4919)</div><div class='quotemain'><!--QuoteEBegin--><!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo-->the one with warter level and rear brake bulb)<!--sizec--></span><!--/sizec--><!--QuoteEnd--></div><!--QuoteEEnd-->
I would be very worried if I was you tbh. It says on your name thingey you have an 8v, there for neither of thouse two lights should ever come on as 8v's did not have check control. There is not wires going to the bulb... thinking about it, there is no bulb in the dash cluster.
Are you sure it was not the warning brake light, like when you have the handbrake on. From my past with Vauxhall's that is normaly the early start of electrical problems. Are you just around the 80,000mile mark by any chance?
EDIT; keep an eye on the air bag light...
wilkybar-kid
by Twangy » Fri Sep 22, 2006 12:30 am
Bear in mind he has an 8v out of a cavalier! Its not a stock calibra 8v, I think Paz has told me before but i was probably drunk and cant remember the differences.
Twangy
by wilkybar-kid » Fri Sep 22, 2006 12:31 am
Still wont have check control, that was wired to the car, not the engine.
EDIT: If it is not the standerd Calibra 8v lump, it wont be the C20NE then will it???
wilkybar-kid
by Twangy » Fri Sep 22, 2006 12:35 am
I dont think so? There were some differences, just cant remeber what...Its on a thread about power issues, only a couple of days old! Ill have a look.
Twangy
by andy1 » Fri Sep 22, 2006 12:39 am
twangy no difference other than the belts,
wilkybar-kid postive it is not the warning b/light or the air bag
but she use to be a auto would the dash lights be the same
andy1
by Twangy » Fri Sep 22, 2006 12:39 am
Quote: the only differences where the drive belt on the old engine had round teeth as the cogs did, and one wide fan belt, the new engine had sq teeth and cogs and two fan belts : End Quote.
Apparently thats the only difference.
Twangy
by wilkybar-kid » Fri Sep 22, 2006 12:43 am
I meen keep an eye out for the air bag light, if it comes on then start to rearly worrie. I had a simmaler problem on my last 2 Calibra's, and my 2.0 8v cav, all started out with the bulb flickering like that, then it stayedon rearly bright, followed by outher light including air bag lights... always happend around 80,000miles, is an electrical problem, and not a cheep one from memory.
But, not sure if they are the same, the cav was though...
wilkybar-kid
by andy1 » Fri Sep 22, 2006 12:43 am
<!--QuoteBegin-Twangy+--><div class='quotetop'>(Twangy)</div><div class='quotemain'><!--QuoteEBegin-->Quote: the only differences where the drive belt on the old engine had round teeth as the cogs did, and one wide fan belt, the new engine had sq teeth and cogs and two fan belts : End Quote.
Apparently thats the only difference.<!--QuoteEnd--></div><!--QuoteEEnd-->
the engine that came out of mine had a wide fan belt 1995, but the engine i put in had two belts 1993 cav
andy1
by Twangy » Fri Sep 22, 2006 12:47 am
May well be the C20NE then! Certainly sounds the same.
Twangy
by andy1 » Fri Sep 22, 2006 12:47 am
<!--QuoteBegin-wilkybar-kid+--><div class='quotetop'>(wilkybar-kid)</div><div class='quotemain'><!--QuoteEBegin-->I meen keep an eye out for the air bag light, if it comes on then start to rearly worrie. I had a simmaler problem on my last 2 Calibra's, and my 2.0 8v cav, all started out with the bulb flickering like that, then it stayedon rearly bright, followed by outher light including air bag lights... always happend around 80,000miles, is an electrical problem, and not a cheep one from memory.
But, not sure if they are the same, the cav was though...<!--QuoteEnd--></div><!--QuoteEEnd-->
the car has done over 108,000 but new engine has about 123,000 thats all figures add up as the new engine had around 117,00 when it came out of cav
andy1
by andy1 » Fri Sep 22, 2006 12:49 am
<!--QuoteBegin-wilkybar-kid+--><div class='quotetop'>(wilkybar-kid)</div><div class='quotemain'><!--QuoteEBegin-->Still wont have check control, that was wired to the car, not the engine.
EDIT: If it is not the standerd Calibra 8v lump, it wont be the C20NE then will it???<!--QuoteEnd--></div><!--QuoteEEnd--> i think in the cav manual they called it somthing differnt
andy1
Users browsing this forum: No registered users and 42 guests
