Dash Board light
there are 2 similar lights,
one comes on with ignition and stays on until you touch the brake... (this is a brake waring/test light its normal to be on until you first tap the brake.)
the other is a bulb, fault light, if its on then one of your bulbs doesnt work, probably not a brake light, reverse or indicator if its only at night that you notice it.
check your rear side-light, that went on me, its a bit hard to see in the daylight.
carl_freeman
<!--QuoteBegin-carl_freeman+--><div class='quotetop'>(carl_freeman)</div><div class='quotemain'><!--QuoteEBegin-->ps KevV6,
if you live near basingstoke, you should come to our Hook Meet... (1st sunday of each month, just outside basingstoke.) see the local minimeets section of the forum for details. its good fun, normally about 10-15 Calibras... (oh, but there isnt one in June.)<!--QuoteEnd--></div><!--QuoteEEnd-->
Hi Carl, He has been to the Hook meets mate, Me and Ian (Splinter) have tried to get him to post on here more often (lazy git) i shall have to twist his arm a little bit more
[img]/laugh.gif[/img]
Jay, does the forum support HTML imagemaps?
Just I was toying with the idea of doing a pic of the dash with popup comments for each light, seeing as it's a fairly regular question..
If not I guess I can stick it up on my own webspace, just might be nice to have it in the FAQ section..
UPDATE:-
Had a quick go at it, need to do all the other warning lights tho, and would look much better with a pic of a real dash...
Put the cursor over a 'light' and it pops up (or should do) the description from the manual.
Obvisouly this could be expanded for more info..
<a href="http://www.raiden.pwp.blueyonder.co.uk/dash.html" target="_blank">]Dashboard warning lights</a>
UPDATE:-
Leigh
just drove home from work tonight, no sign of the light on the dashboard...screwy electrics like my last vauxhall i guess. Thanks for the help though carl and jay....i'll copy that diagram for future reference, cheers. Yes been to a few meets already, will try my best to attend. I did make castle combe though ! 2 posts now Rob...offthe mark at last !! Lol
KevV6
<!--QuoteBegin-KevV6+--><div class='quotetop'>(KevV6)</div><div class='quotemain'><!--QuoteEBegin-->just drove home from work tonight, no sign of the light on the dashboard...screwy electrics like my last vauxhall i guess. Thanks for the help though carl and jay....i'll copy that diagram for future reference, cheers. Yes been to a few meets already, will try my best to attend. I did make castle combe though ! 2 posts now Rob...offthe mark at last !! Lol<!--QuoteEnd--></div><!--QuoteEEnd-->
Bout bleedin time [img]/laugh.gif[/img]
