temp sensor for outside temp
by carson » Wed Oct 04, 2006 11:41 am
is the temp sensor under the bumper common to all vauxhalls? showing -15,im in newquay at the moment and im sure it aint that cold,assuming its the sensor or could it be sumit else?
carson
by carson » Wed Oct 04, 2006 12:04 pm
by common to all vauxhalls i mean are they all the same on all models?
carson
by Cozy » Wed Oct 04, 2006 12:13 pm
its in the front bumper, this is taken from the guide to fit a cold air feed and
Finally the last step before you can remove the front bumper is to disconnect the ambient temperature sensor. Slide the front bumper a few inches forward carefully. Just to the right hand side there is a small sensor attached to the bumper it pulls out quite easily.
Cozy
by Robs-se » Wed Oct 04, 2006 1:59 pm
<!--QuoteBegin-carson+--><div class='quotetop'>(carson)</div><div class='quotemain'><!--QuoteEBegin-->is the temp sensor under the bumper common to all vauxhalls? showing -15,im in newquay at the moment and im sure it aint that cold,assuming its the sensor or could it be sumit else?<!--QuoteEnd--></div><!--QuoteEEnd-->
Certainly the same as a mk3 astra as i have performed a swap on these
Rob
by Robs-se » Wed Oct 04, 2006 2:00 pm
try cleaning the sensor with a spray of wd40.
Might be full of ice :icon_mrgr
Rob
by andy1 » Wed Oct 04, 2006 3:28 pm
mine is reading -2.0
andy1
by carson » Wed Oct 04, 2006 3:52 pm
thanks people
carson
