Rogue connector
Rogue connector
Found this connector just dangling by the passenger side front wheel behind the bumper, any idea's?
Also where is the temp sensor meant to fix to as it was just dangling down next to it?
Andy_cdti
<!--QuoteBegin-callyben+--><div class='quotetop'>(callyben)</div><div class='quotemain'><!--QuoteEBegin-->thats looks like the pad wear sensor or abs sensor plug<!--QuoteEnd--></div><!--QuoteEEnd-->
Hmm there wasnt that much play in the lead to get it all the way back to the brakes.... Seemed to be on same loom as the horn
Andy_cdti
