speedo needle jerks when steering turning?
by calibra_v6_dtm » Tue Nov 14, 2006 12:25 am
Hi guys,
strange one this...
noticed recently when parking the speedo needle jerks like to 10 or 15mph when turning the steering sometimes.
any ideas what could cause it?
Matt
calibra_v6_dtm
by sam_p2000 » Tue Nov 14, 2006 2:08 pm
Mine does this too strangely...also a V6 on a m plate. Someone told me it was a characteristic of some of them and not to worry about. But then wouldnt be the first bit of bad advise vauxhall have given me!
sam_p2000
by calibra_v6_dtm » Tue Nov 14, 2006 8:26 pm
thanks for the replies, i'll check the abs sensors.
calibra_v6_dtm
by Robert_Dale » Tue Nov 14, 2006 8:44 pm
if its mechanical mate just check the cable running from the back of the speedo - it comes out behind the dash in the engine bay, it might be leaning on something when you turn, just make sure its secure!
Robert_Dale
by calibra_v6_dtm » Wed Nov 15, 2006 12:57 am
nah its electronic mate (v6) abs sensors seems most likely thinking about it, will try have a look when its dry out next
calibra_v6_dtm
by sinbrad » Thu Nov 16, 2006 11:27 pm
Strange thing, I got the erratic speedo thing as well, '97 plate though. Looked at V6 calibra and it states on there that this is one of the first signs of an ABS sensor on it's way out or at least developing a fault. Lo and behold not much longer after the initial speedo jumping did the ABS sensor fail. Just waiting for a replacement from autovaux to arrive
