Outside temp sensor
Underneath the passenger side front bumper, just around the point where it starts to curve around to the side, if you lie on your back or crane your head under, there is a small hole, probalby no more than 1cm across, the temp sensor clips into this from the inside of the bumper. (i.e you reach under and back into the bumper with your hand.
All you will see of it from underneath is the tip of the sensor, and the little 'prongs' that clip it into place.
Leigh
If your car was fitted as standard with the analogue clock, then it's really unlikely that you will have the wiring already there.
The DID is easy to wire up though, all of the connections you need can be taken either from the radio loom or the existing clock loom, then you will need to run wires for the temperature sensor, which need to connect into the fuel computer loom, which will be hidden away in your dash somewwhere.
Hope that helps, Ian.
IanT
<!--QuoteBegin-IanT+--><div class='quotetop'>(IanT)</div><div class='quotemain'><!--QuoteEBegin-->If your car was fitted as standard with the analogue clock, then it's really unlikely that you will have the wiring already there.
somewwhere.<!--QuoteEnd--></div><!--QuoteEEnd-->
Not true, as Cally wiring looms are the same, if you have Fuel Computer wiring then you should have a place where the temp sensor goes.
K5
Finally getting round to fitting the temp sensor to my Calibra,
But where is the wiring for it,
Cut the loom back around/under headlight but found no temp sensor wire's,
Where can I join up or find the connector,
I did have to rewire the switch to Fuel computer as there was no wire's there for that either.
93 Calibra 8v
93 Calibra 8v
SprintV8
