Another attempt at remote central locking?!
Hi All,
Fitted the Cobra remote locking kit on Sunday and it works fine. It locks and unlocks but I have yet to find a suitable place to connect to the flashers so it does so un-flashingly
. All of the connections to make it work are to the central locking box behind the driver's kick plate, but I will probably have to go through the bulk head to connect the flashers. The longest time was spent double-checking the connections against the wiring diagram in the Haynes manual before making connections. Window lifting doesn't work, but I suppose that is associated with the switch at the second key position which I haven't connected to.
Recommended...
<a href="http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=15329&item=7906157953" target="_blank">http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...item=7906157953</a>
Keith [img]/smile.gif[/img]
Recommended...
Ivorcally
keith, if you have a look at this
<a href="http://www.clubcalibra.net/modules.php?op=modload&name=Sections&file=index&req=viewarticle&artid=18&page=1" target="_blank">http://www.clubcalibra.net/modules.php?op=...artid=18&page=1</a>
Go to the passenger side under the glove box and locate a BLACK/GREEN and a BLACK/WHITE striped wires, these are the indicator wires.
On the drivers side kick panel near the central locking box is a BROWN/BLACK wire, this is the window close signal wire, but i dont know if this will work with the Cobra kit might be worth a try [img]/smile.gif[/img]
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->Go to the passenger side under the glove box and locate a BLACK/GREEN and a BLACK/WHITE striped wires, these are the indicator wires.<!--QuoteEnd--></div><!--QuoteEEnd-->
Thanks Robbie [img]/smile.gif[/img]
I'll check the brown/black wire for window opening too.
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->Have you set yours to chirp on locking / unlocking?<!--QuoteEnd--></div><!--QuoteEEnd-->
Smurf, I don't think my kit has this feature, but it may be that it is not mentioned in the manual.
Cheers,
Cheers,
Ivorcally
<!--QuoteBegin-Ivorcally+--><div class='quotetop'>(Ivorcally)</div><div class='quotemain'><!--QuoteEBegin-->Hi,
Robbie, I found the wires behind the passenger kick plate and now have flashy lockers!
Cheers,
Keith [img]/smile.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
Well done [img]/smile.gif[/img]
Cheers,
Users browsing this forum: Bing [Bot] and 16 guests
