re-looming
re-looming
by heavenly_d3vi1 » Mon Feb 19, 2007 1:01 pm
oh so helpfull brains of club calibra, once again... i require your knowledge!
im re-looming the turbo coz im fed up searching for electrical problems that cant be found! apparently i dont need the engine loom, just the car loom.. so would that be teh same as any cally/cav?
heavenly_d3vi1
by T.F.S. » Mon Feb 19, 2007 1:34 pm
the loom inside the car?, that does not normally go wrong as its proteced from weathering being inside the car
so you maen loom for air-con, heater, lights etc?, not injection loom?
T.F.S.
by heavenly_d3vi1 » Mon Feb 19, 2007 1:36 pm
erm.. the one inside the car im guessing... it has cuts ad slices all oevr the place.
heavenly_d3vi1
by T.F.S. » Mon Feb 19, 2007 1:39 pm
jeez, you will have to remove the dash i would have thought....not a quick job!
are you doing this yourself ju?
T.F.S.
by heavenly_d3vi1 » Mon Feb 19, 2007 1:40 pm
lmao, erm.. no! and yes i know its gunna take a bit of work.. tahts why im buying a second car lol. but, i still need to know if any cally/cav looms will be ok!?
heavenly_d3vi1
by T.F.S. » Mon Feb 19, 2007 1:47 pm
oh, well i guess you would simply need an air con version loom, i have not changed one but they should all be the same for air con models
T.F.S.
by T.F.S. » Mon Feb 19, 2007 1:54 pm
engine cutting out will be injection loom!
if you have issues with heater, aircon, interiour/exterior lights etc then that is car loom
injection loom is pretty easy to change too!
T.F.S.
by Stupink » Mon Feb 19, 2007 1:55 pm
It's more than a bit of work. It's practically insane to contemplate doing to a complete road car. I would strongly advise against doing it. Tracing it around and repairing any faults is going to be FAR the easier/quicker/cheaper etc etc job, no matter how hard it may seem to be.
If you want the answer to your question though, I would reccomend the vaux EPC catalogue to look up the loom part number of several models etc, but as bri says as long as its a similar spec then I don't see it will be different. hence the reason for having a seperate engine loom.
for the alarm removal you will only have cuts around the ignition barrel and the wires heading towards behind the radio section, and in the passenger footwell behind the glove box etc.. It really wouldn't be much trouble to have a good gandy over it all and ensure its all ok.
by heavenly_d3vi1 » Mon Feb 19, 2007 4:03 pm
the loom has been completely gone over several times and lots, and lots of cuts repaired in places that we coulnd't even find a reason for having cuts in... including in the engine loom, there was a wire in the engine loom that wasn't even there at all (cant remember which now). so, its the engine loom i need then?
heavenly_d3vi1
