cant get to work
cant get to work
by yellowfever » Sat Mar 03, 2007 12:19 pm
ive just wired up my 6x9 running of a amp,got light on amp that must be the remote power,but i have no sound out of speakers,the only thing i can think of is a bad earth or on the amp where u put in the earth,power,romote,the conectors move in and out is this normal,any info would be cool
yellowfever
by yellowfever » Sat Mar 03, 2007 4:29 pm
ive just checked speakers they work ok,headunit works all ok ie rca conectors.had a look inside amp everything seems ok,but still cant get it to work,help
yellowfever
by blue redtop » Sat Mar 03, 2007 5:15 pm
9 out of 10 times its the earth,move the earth,(i use a bolt holding the rear lights in)
and make sure u have a fuse in the live wire.(the light on the amp will still come on even if the fuse is missing or blown)
hope this helps
jay
blue redtop
by yellowfever » Sat Mar 03, 2007 6:20 pm
i tryed the earth took it straight from battery still no good mate
yellowfever
by MJ » Sat Mar 03, 2007 6:21 pm
how thick is the wiring your using?
MJ
by yellowfever » Sat Mar 03, 2007 6:41 pm
live&earth as thick as a pencel
yellowfever
by MJ » Sat Mar 03, 2007 8:27 pm
ah pencil thickness should be sufficient .... just checking! [img]/smile.gif[/img]
MJ
by yellowfever » Sat Mar 03, 2007 10:55 pm
yer i pluged in a dvd player had no probs with the sound using the rca conectors
yellowfever
