Brake Lights
by Taz » Fri Feb 06, 2004 2:26 pm
My rear left brake light is not working properly. When I turn my headlights on, and the rear light come on, the left brake light in permently on, (the right on is fine). When the lights are off and I press the brake pedal, the left brake light is brighter than the left.
Does anyone have any suggestions as to how I may fix this problem?
Cheers!
Taz
by skellem » Fri Feb 06, 2004 2:46 pm
It deffo sounds like a short in the wiring somewhere. Have you moved or played with any of the wiring looms near the boot recently?
skellem
by Fraz » Mon Feb 09, 2004 7:45 pm
Check the brightest bulb is not double filament one,and its using the brake light filament... hence it will be brighter
seen it done a few times
by aitchy » Mon Apr 10, 2006 4:08 pm
hi,i'm new here can you help.With the light switch off my nearside brake light works but not as bright as the offside,when I press the bake with the lights switched on it goes out altogether,all the other lights work fine
aitchy
by wilkybar-kid » Mon Apr 10, 2006 6:01 pm
sounds to me like the buld is in the wroung way around...
wilkybar-kid
