Rear Passenger Side Light Problem
by Twangy » Sat May 05, 2007 3:36 pm
Hi,
Got a problem with the rear passenger lights. Everything else is working in the cluster apart from the tail light and the brake light. I swapped the bulbs from the drivers side to see if it was just the bulb, but it blew it when the brake pedal was pressed. Any ideas as to what is causing this.
Ta
Twangy
by Phantom » Mon May 07, 2007 10:28 pm
I'm assuming you have a short somewhere, do you have a voltmeter to check the voltage at the connections?
