Warning lamps on dash
by poundsy » Tue May 22, 2007 7:35 pm
Hi,
Can anyone help me, i've racked my brains and cant figure this out.
A few weeks ago my brake warning light came on and stayed on, i changed the pads, Front and rear, but there was no warning lead going to any of the pads which i thought Odd.....
I've checked the fluid level and thats fine but the damn light still wont go out!!!
Whats eerie is the pads did need doing??????
HELP!!!!
Mike
poundsy
by RobbieV » Tue May 22, 2007 7:57 pm
Are you sure it's the brake warning light, have a check via the pic [img]/smile.gif[/img]
by heavenly_d3vi1 » Tue May 22, 2007 8:09 pm
if the sensor thingys aren't there wont the light be on anyway? mine was always on on my old cally coz i didn't have the sensors
heavenly_d3vi1
by ecosseM » Tue May 22, 2007 8:31 pm
just join the wires, make the circit, thats the easy fix with pads prob, aslong as you know pads etc ok and keep an eye on them, actualy, on some models there is only one side with a sensor, my v6 was like that, it had a dummy plug on the o/s (witch must of had wires connected up inside, to make circit)
ecosseM
by Shrek » Wed May 23, 2007 9:35 am
both my bulb warning lights keep coming on 4th and 5th from left any ideas on that sorry to hijack thread.
Shrek
by poundsy » Wed May 23, 2007 11:38 am
Thanks guys,
Robbie, re-checked and its definately the pad worn lamp.
Heavenley, i'd agree with you but the lamp wasn't on before, think i'll try and trace the wiring from the relays.
ecosseM, i didn't really want to just join them up, i'd rather find the fault, but i guess i might have to in the end.... isn't it strange how you can start to hate the colour orange lol..
ZXRick, have you tried checking to make sure the lamps are grounded properly? if there's only a slight ground, then the lamps will work but will change the resistance of the circuit which may be enough to trigger the sensor??? Just an idea cos mine is on but i know there's a problem with the headlight wires
Again, cheers everyone...
poundsy
by poundsy » Wed May 23, 2007 11:39 am
Ecosse, do you know where the dummy plug was located??
poundsy
by lammy » Wed May 23, 2007 11:17 pm
Just trace them back to the inner wheel arch and connect them together with some wire (leccy tapeover them) and the light should stay out like Ecosse said..its easy to do.
SE9
by poundsy » Thu May 24, 2007 1:03 am
cheers think i'll have to.
poundsy
by Phantom » Thu May 24, 2007 12:03 pm
or you could always buy the sensors
by Phil » Thu May 24, 2007 5:25 pm
Some callys only have one sensor.....
Mine doesn't have any! Not all models had such a thing.
Phil
by willster174 » Fri Jan 18, 2008 1:03 pm
I have this problem on mine and there does not appear to be a sensor fitted and there is only one wire so what do I attach the wire to to turn off the lamp on the dahboard??
Any help appreciated???
willster174
by RobbieV » Fri Jan 18, 2008 1:08 pm
willster174 wrote:I have this problem on mine and there does not appear to be a sensor fitted and there is only one wire so what do I attach the wire to to turn off the lamp on the dahboard??
The pad wear sensor plugs into a two pin plug which is clipped to the inner wheel arch, one method is to use a paper clip and insert it into both holes on the plug and tape up.
Next time you buy pads with sensors take off tape pull out paper clip and plug in sensor.
by willster174 » Fri Jan 18, 2008 1:25 pm
Thanks mate will try that
willster174
Users browsing this forum: Majestic-12 [Bot] and 20 guests
