fault code 44 ???? any ideas
by warby » Sun Jun 03, 2007 11:27 pm
ecu light keeps comin on then goin off did a paper clip test n came back with fault 44 oxygen sensor air/fuel 2 lean(weak) now the lambo sensor only 2 months old n ive cleaned the i,c,v any ideas any1?????
warby
by tombstone » Sun Jun 03, 2007 11:47 pm
air leak? try spraying carb cleaner around inlet and intake pipe with engine idling, if engine note changes drastically air is getting in where it shouldnt. air flow meter???
tombstone
by warby » Mon Jun 04, 2007 12:54 am
cleaned inlet not 2 long ago will try that in the mornin no code 4 air flow meter n it pritty clean
warby
by warby » Wed Jun 06, 2007 12:43 am
nout happpened n light still keeps comin on any ideas???
warby
by Stupink » Wed Jun 06, 2007 8:21 am
Is it actually running too lean? does the code come up on driving or idle too?
by warby » Wed Jun 06, 2007 8:43 am
spark plugs are black n when code turns up its there when drivin or idle n usng a lot a fuel code cames n goes cant work it out
warby
by Stupink » Wed Jun 06, 2007 9:17 am
black is too rich not too lean.
are you sure the new lambda sensor works ok? fault code didnt start appearing after you installed it by any chance?
by warby » Wed Jun 06, 2007 9:32 am
i no thats wots doin my nut there black but code says 44, fitted it a couple of months ago only just started playin up a wk or so ago was code 13 got rid of that now its keeps sayin 44 could the lambda be playin up
warby
by Stupink » Wed Jun 06, 2007 9:38 am
get the sensor checked, look at topbuzz.co.uk for info on testing yourself or take it to a garage with a box doobery to plug in.
by warby » Wed Jun 06, 2007 9:44 am
will try n test the sensor it could be that if i diconnect my battery 4 a couple of minutes it goes away but comes back after a hour or so of runnin
warby
by warby » Sun Jun 17, 2007 9:35 pm
still no luck ran ok 4 abit but as soon as it starts gettin warm theres wot feels like a blokage 4 a sec then the light comes on then its run ok its eatin fuel any ideas its doin my nut
warby
by rcptcarrot » Sun Sep 09, 2007 8:20 pm
warby wrote:still no luck ran ok 4 abit but as soon as it starts gettin warm theres wot feels like a blokage 4 a sec then the light comes on then its run ok its eatin fuel any ideas its doin my nut
Have you checked the crankshaft sensor?
rcptcarrot
