Is my alternator on the way out?
by ross85 » Mon Jul 30, 2007 4:03 pm
There's a whirring sound coming from the left hand side of the engine which gets louder when the revs increase. I took the auxiliary belt off and ran the engine for a few seconds and the whirring disappeared so am I right in thinking the alternator needs replacing?
ross85
by EY » Mon Jul 30, 2007 4:18 pm
Could be the alternator, or the tensioner roller. Have you tried giving them a little squirt of lube? Obviously avoiding the belt, and the internals of the alternator.
by ross85 » Mon Jul 30, 2007 5:30 pm
Right, just come in from putting some lube on, left the car running for 5 minutes and there's no immediate improvement. The missus is taking it out later so will see if it's better when she comes back.
ross85
by Robs-se » Mon Jul 30, 2007 8:57 pm
mine does it, but it need the belt replaced because it slips slightly.
Try a new belt
Rob
by ross85 » Tue Aug 07, 2007 8:21 pm
I swapped the alternator with the one on my other ecotec which was running fine and the sound is still there - how difficult is a belt change as it runs through an engine mount?
ross85
by ross85 » Wed Aug 08, 2007 12:49 pm
Will be looking into it then, might end up taking it in if I don't get if fixed before I go on holiday.
ross85
by ross85 » Thu Sep 06, 2007 9:08 am
Fixed it in the end, the top bolt on the tensioner housing had come loose :)
ross85
