Cruise control?
Cruise control?
I bought a Cruise control kit from an omega of ebay a while back, every thing looks ok when I bought it, looking through some wiring details I had found on the web, but I havnt got a switch for the clutch. What can I use that will do the job?
A_Venables
I think you will have to get a switch that is normaly closed and the brake switch is normaly open, so if you use that then you will have to use a relay or something as well, im pondering this very question at the moment because the clutch pedal seems not to have a mounting on the clutch for a swich like the vectra
Ricardoco
