angel eye transformer question...
i recenly aquired 2 sets of angel eye neon rings to convert into my lights , but they never came with any transformer blocks only bare wires.
Ive looked on fatladz old website
http://www.aqth92.dsl.pipex.com/calibra ... _guide.htm
and it doesnt say how you connect them to normal lighting systems...can anyone help and give me a bit of advice how to link them
ah i see i thouht they were neon , okay well i guess led is better ,so hows the best way to wire to the sidelights (as ive never done any electrics modifiying before lol...
btw do i still keep my existing sidelights as i found a old thread where someone said the halos replace the sidelights...
scouse1 wrote:were can you get the led ones from?
They were ripped out of the "sonar" angel eye headlights that are sold on ebay.
The neon angel eyes are better -
http://stores.ebay.co.uk/1llusion-CarSt ... esstQQtZkm
ok ive just found a guide for fitting the rings on a ford mondeo here :http://www.fordmondeo.org/wiki/index.php/Angel_Eyes_-_Mk2
, so im sure this will help especially as i can use a connection block for the led angel rings to connect up and because i already have a set of calibra lights i can use these to experiment with.
arent they the headlight adjusters. the stalk end fits into the hole underneath the plug in baz
okay so they are for the electrical switch inside the car used for raising and lowering the positions is that correct.
ive just had a look under the bonnet but mine look different as it looks like they have a grey plastic screw on the end of the adjuster, is this normal for all models of calibra or are they all different.
are you saying that yours are manually adjusted rather than electric. got a pic mate?
nah , they just look different from the back....
i know my electrics work inside the car okay so i would say they are still electric.
as for the brightness i know your right dave clear lenses would look better but its a little bit of extra light source and fatlaz started off with the standard cally lights as at the bottom of this link:
