URGENT!! sunroof won't close and it's starting to rain
Hoping somebody can help me....I opened my sunroof this morning to let out the filthy smell my friend had just created and now it won't close again.I only opened it upwards didn't slide it back but now if I try to close it I get nothing but if I try to open it some more I just get a loud clunking noise.Is there anyway I could close it manually for the time being? Appreciate any info anybody can give.cheers. Neil
M005tng
if all fails don't worry too much. the sunroof is very well designed, it can cope with the vast majority of rain types/angles so long as its only tilted not moved back. unless the rain is torrential golf ball sized drops and/or being blown horizontal by a hurricane it will probably stay all but dry inside.
tried closing it with the allen key but it just kept unscrewing and out comes a screw with a little cog on.lol.I tried using the the buttons whilst I could see the motor and it turned slightly so the motors not dead.So I pulled the rubber seal from around the sunroof opening and had a peek over the roof lining and it turns out the passenger side runner isn't moving at all when I press the button.But if I try moving the actual sunroof itself with my hands the passenger side moves so it looks like the runner has disconnected somehow.I was thinking of unscrewing the hinge but it looks like its all rivets or something.will I have to take off all the roof lining and if so how do I go about acheiving that.
M005tng
How to remove the headlining from Wilkybar-kid (Richard)
http://www.clubcalibra.net/viewtopic.ph ... highlight=
I just don't worry about...............................I've not got one.
