Glove compartment light
Ok guys, as above the glove compartment light just suddenly stopped working. Checked all fuses etc and all seem fine. Cheched the bulb and it works connected to a battery. Bought a new bulb anyway and that doesn't work either. Checked the cigarette lighter and there is power coming from it. The light that lights up the cigarette lighter isn't there and wondered if the fuse for the glove box was the same one for either the cigarette lighter or it's light? Maybe something simple but it's stumped me!
Got it sorted so you can all rest in peace now! Anyway what it was was the little switch type thing that disconnects the light when the glove compartment door is shut wasn't making a true connection. Bent it a little bit and it now works.
sinbrad wrote:Yeah, still waiting for some help on my steating, whish that was easy! Seperate post?
Seperate post??
sounds like thats a question if you should start a sperate post or not, I can't even see anything about a problem with your "steating" in this post???? probably why no one has replied..
not sure if you mean steering or seating.
