Fuel Guage
Fuel Guage
by clark607 » Sat Dec 15, 2007 5:30 pm
I have finaly got my Calibra back on the road, but the fuel guage has stopped working. Any ideas?
clark607
by clark607 » Sat Dec 15, 2007 5:59 pm
ok thanks, i have filled her up and the F2 Fuse is ok.
wiring or sender fault then?
clark607
by Calibra_Mike » Sun Dec 16, 2007 7:20 am
more than likely
by grumpy » Mon Dec 17, 2007 12:59 am
funnily enough mine stopped working a while back. had to replace the whole clocks unit. to test to see if its the clocks first before you go to the hassle of getting the tank out. underneath the seats in the rear you will get the two wires from the float in the tank. carnt remember the colour wires. will check in the morning. just short out the two of them and if the fuel gauge flies up then you know its an in tank job. if not then its probably the clocks that need replacing. hope this helps
grumpy
by clark607 » Mon Dec 17, 2007 1:08 am
Thanks for the help, if you know the colour of the cables tomorrow please let me know thanks.
clark607
by grumpy » Mon Dec 17, 2007 2:41 pm
its the blue with a black trail, and a brown. its the only two 0.75 mm wires there. just make sure you short them out the clocks side of the cut.
grumpy
