code 21
code 21
by r1 nod » Mon Dec 17, 2007 10:04 pm
did paper clib test 2day gettin code 21 throttle position sensor high voltage what does this mean and how do i fix it also the low oil level warning light is comin on even do its full of oil any ideas cheers
r1 nod
by Stupink » Mon Dec 17, 2007 10:47 pm
Which engine is this? the throttle position sensor is on the throttle body, voltage high usually means a break in the wire or the plug has come off etc..
the low oil level could be the sensor in the sump, or as simple as a break in the wiring again.. follow the wiring up from the sump to the first connefctor plug and unplug it, short out the two pins on the loom side the light should go out if thats ok, meaning its the sensor side.
by r1 nod » Mon Dec 17, 2007 10:49 pm
16v red top
r1 nod
by Stupink » Mon Dec 17, 2007 10:58 pm
oil level sensor is on the front of the sump then, and throttle sensor on the left hand side of throttle body secured with two screws, little black thing
