ELECTRICAL
ELECTRICAL
by pete i200r » Thu Jan 03, 2008 11:38 pm
CAN SOMEONE HELP ME!! MY 95 8V CUTS OUT!! SOME TIMES FOR 1-3 SECONDS, AN SOMETIMES ALTOGETHER!!?? AND WONT START FOR3-10 MIN'S. THE REV COUNTER DROPS AN THE ENG-MANAGEMENT LIGHT COMES ON. BUT WHEN ENG KICKS IN AGAIN REVS WORK AN LIGHT GOS OUT!! PLEASE HELP NEED CAR FOR WORK. THANKS. PETER. PS. CAN TXT ME-- (07857122279)
pete i200r
by truxx » Thu Jan 03, 2008 11:41 pm
Do a search for paperclip test and try that,it will give you the fault code...
http://www.topbuzz.co.uk/info/fault_cod ... _codes.htm
truxx
by Calibra_Mike » Fri Jan 04, 2008 8:34 am
Paperclip test...
Could be a sensor of some sort... the paperclip test will give you then engine fault codes, post them up on here and go from there...
by pete i200r » Fri Jan 04, 2008 10:09 am
thanks...! i'll try that an see how it go's.
pete i200r
by RobbieV » Fri Jan 04, 2008 3:13 pm
Possible fuel relay fault.
by Allys Cally » Fri Jan 04, 2008 3:57 pm
fuel pump or as robbie says fuel relay.
by pete i200r » Fri Jan 04, 2008 4:25 pm
where is the fuel pump relay on the 95 20i 8v??? i had trouble start'n it 9 years ago an put an fuel injection relay in and that was that; till now!!! great car! but this is dangerous!!! had my wee gril in car 2day an cut out at junction :evil: HELP!!!
pete i200r
by RobbieV » Fri Jan 04, 2008 4:40 pm
You should find it in the drivers side foot well, small black relay near the central door locking module.
by pete i200r » Sat Jan 05, 2008 11:05 pm
what about a CRANKSHAFT SENSOR!!!!!! could it be it????
pete i200r
by pete i200r » Tue Jan 08, 2008 12:12 pm
put a crankshaft sensor now.....but stil the same!!!??? v/hall dealer will hav fuel relay thurday hope that dos it :? :? :?
pete i200r
by pete i200r » Thu Jan 10, 2008 9:22 pm
yepeee think thad done it!!!! put new fuel injection/pump relay in y-day an has't cut-out yet :D :D :D thanks to all that replied to my post :wink: :wink: good to know help is out there.
pete i200r
by tazz666 » Thu Jan 10, 2008 10:09 pm
there all good guys and girls on this site,
tazz666
by pete i200r » Sat Jan 12, 2008 12:53 pm
tazz666-- you not sell'n your 16v now????
pete i200r
