Interior Lights
Interior Lights
Just a couple of questions, I dont have any light behind the headlight switch, should this have it as standard or is it only if you take it apart and fit an led in there yourself?
Also my heater controls dont seems very brings, is this common, Ive just bought a kit for replacing the bulbs so will be getting it sorted, just wondered if its the same on other calibras...
Re: Interior Lights
Calibra_Mike wrote:Also my heater controls dont seems very brings, is this common, Ive just bought a kit for replacing the bulbs so will be getting it sorted, just wondered if its the same on other calibras...
1.First the 2 screws on the ignition cowling...
Or can be seen better from this pic (borrowed from skellem)
pic shown with steering wheel removed,but this job can be done with wheel left on.
then lift the top of the ignition cowling off.
2.Then the bit of plastic trim that runs along below the clocks...
This is fairly awkward to get out,you just got to mully it a little at the ends.once one end comes out it's easy.
3.Now you can remove these 2 screws that holds the heater unit in place
And another 2 screws on the other side of the unit,behind the clock.(the trim round the clock just pops off,then 2 clips top and bottom hold the rest of the clock in place,just nip them towards eachother and pull the clock out.)
4.Once you have done that,you can pull the heater controls unit towards you a couple of inches.
and you will see this:
The small plastic bit that the 2 spade connectors are attached to just pushes back over and you will see the bulb:
The old bulb just pulls out...
No doubt you allready know how to do this,but thought id post it incase it might help someone else.
HTH
Dave
truxx
Users browsing this forum: No registered users and 42 guests
