fuse box heater fan fuse
HELP!! My car is soooo cold!! I can't find the manual for my V6. I need help locating the fuse box so I can change the fuse for the heater fan (is it 30A??) also can someone tell me the exact postion of said fuse?? Thanks!!
charlylou
Fuse list to be found in -
ClubCalibra.net Forum Index » Technical » General Technical
http://www.clubcalibra.net/viewtopic.php?t=28055
Fuse List
1. 10A - Parking and tail lights Left
2. 20A - Heated front seats, Cigarette lighter, Control Indicators
3. 10A - Main beam left
4. 30A - Heater fan (*1)
5. 10A - Dipped beam left, Headlamp range adjuster
6. 30A - Front/Rear Wipers
7. 15A - Turning signal lamps, brake lamps ABS
8. 15A - Courtesy lamp, Luggage compartment lamp, Hazard warning flasher, Dual info display, Radio, Trip computer
9. 10A - Instrument illumination, Number plate lamp, Traction control
10. 30A - Sunroof
11. 20A - Fuel pump
12. 10A - Electrically adjustable exterior mirror, Electrically operated door windows
13. 20A - Fog Lamps
14. 10A - ABS, Automatic transmission
15. 30A - Heated rear window, heated exterior mirrors
16. 10A - Automatic transmission
17. 20A - Central door locking system
18. 10A - (sweden Only) Daylight driving lamps
19. 10A - Four-wheel drive
20. 20A - Horn
21. 10A - Parking and tail lights Right
22. 10A - Reverse lamps, Dual info display, Trip computer, headlamp warning device
23. 10A - Main beam Right
24. 30A - Cooling fan (*1)
25. 10A - Dipped beam Right
26. - Blank
27. 10A - Fog tail lamp
28. 20A - Terminal 30: constant current for caravan/trailer
29. 30A - Healamp wash system
30. 30A - Electrically operated door windows
31 + 32. - Spare fuses
10. 30A - Sunroof
11. 20A - Fuel pump
13. 20A - Fog Lamps
20. 20A - Horn
26. - Blank
- Attachments
- Fuses.jpg (56.48 KiB) Viewed 6450 times
clark607
Re: fuse box heater fan fuse
hi there im looking for the heater fan fuse ! on the main fuse block under the stearing wheel its missing so i have been told its under the bonnet! so ive looked but there is no guide can any 1 help ??? many thanks
scottie davis
somerset
scottie davis
somerset
scottiedavis
i cant seen to up load a pic on this site so i have put a link up to my photo bucket if any 1 could tell me what each fuse and relay does in the fuse box under the bonnet it would be a great hel also if any1 can copy this pic and get it uploaded so others can see easy'r that woul be great to
happy new year all
scottie davis
somerset
http://i168.photobucket.com/albums/u190 ... C05867.jpg
happy new year all
scottie davis
somerset
scottiedavis
Users browsing this forum: Bing [Bot] and 6 guests
