anyone got the haynes manual that covers...
As above,need to find out which colour relay is for the radiator fan.
I know the relay is located behind the fusebox on it's own bracket,but the manual i have is for a cavalier and doesnt give any info about the fan relay...
On another thread http://www.clubcalibra.net/viewtopic.php?t=28055
Someone called CHIEF has posted some pics of the relay,but the link to the pics is dead...
Any help would be greatly appreciated..
Thanks
Dave
Thanks
Dave
truxx
Well i dont have air-con so im not sure now.
The cavalier manual i have covers 1988-1990 and says all models have the relay,but they also say the relay is located in the box under the engine bay.
On mine i only have 1 30A fuse in there,but behind the fusebox(incar totally seperate to the fusebox) i have these relays:
I just assumed one of these must be it.
In the link i posted above someone (username chief) posted pictures of it,so if there is a relay on one model,i would imagine it would be the same on all models.
Seems a bit strange that there isnt much mentioned anywhere about these hidden relays.
This is sooo annoying
Thanks for the info
Dave
Thanks for the info
Dave
truxx
fattyfattyboomalatty wrote:there must be a relay for it. the current draw from the fan would be too much to go through the switch otherwise.
Yeah i thought as much
( i didnt want to ring you on tuesday m8,I thought it would be a bit cheeky of me to ask you to look at my car on your only day off
truxx
ecosseM
