ecu removal
ecu removal
by smarty100 » Fri Jan 11, 2008 10:02 pm
can any one tell me an easy way to get out the ecu in drivers footwell?
smarty100
by goldtop » Fri Jan 11, 2008 10:10 pm
yeah don't think you'll be asking your bro in law to borrow/look at his haynes manual looser :axed:
goldtop
by Stupink » Fri Jan 11, 2008 10:50 pm
there is no easy, or hard way.
just remove the kick panel trim, undo the 4 (or less) 8mm nuts, unclip the wiring loom, remove the vacuum/boost hose and perform magic and weave the ecu out through any wires and the bonnet release arm thingy.
by smarty100 » Sat Jan 12, 2008 4:44 pm
ok stu ive got the bottom 8mm ones undone just cant find room to do the top 2.
smarty100
by Stupink » Sat Jan 12, 2008 7:15 pm
I usually use a deep reach 8mm socket to get the top ones, a small extension between socket and ratchet should suffice.
