break lights staying on
by paudie » Tue Jan 15, 2008 7:39 pm
hi lads,does any one know what would cause my break lights to stay on while im driving?it only happens every now and then.sometimes if i keep pressing the break it will sort its self out but driving down the road it mite happen again!any help/advice would be great
paudie
by Fraz » Tue Jan 15, 2008 7:41 pm
brake switch on the pedal faulty
by RobbieV » Tue Jan 15, 2008 7:41 pm
How do you know your brake lights are staying on while driving ?
Could be a dodgy brake switch under the brake pedal.
by paudie » Tue Jan 15, 2008 7:50 pm
thanks for the quick replys lads.i can see them on at night while driving and 1 of the lads said it to me well ago when i was coming home from work.is the switch hard to replace?
paudie
by RobbieV » Tue Jan 15, 2008 8:03 pm
Not so much as hard but bloody awkward to get to.
by paudie » Tue Jan 15, 2008 8:17 pm
typical!nothings easy to fix on that car of mine ha ha thanks for the help, thats one problem with the car off my list!!
paudie
by smarty100 » Tue Jan 15, 2008 8:42 pm
does the lighs go out if you put your foot under the brake pedal and lift it up toward you, if so the switch may need adjusting usually they are adjustable
smarty100
by paudie » Wed Feb 06, 2008 9:33 pm
sometimes if i keep pumping the break it will go out!has any one here changed the switch?how long does it take and what exactally is involved in replacing the switch?i plan to take my buddys one fri night because of my nct sat morning!stone broke,cant afford a new one
paudie
by paudie » Sat Feb 16, 2008 2:48 pm
anybody know how to change faulty brake switch on the pedal??
paudie
