Battery / Alternator /Battery warning light
by cali-bra » Fri Jan 25, 2008 11:41 pm
HI
Having trouble with an SE8 16v. Battery warning light comes on when you turn the car off & stays on when you remove the key, .......draing the battery :( Start the car and it goes out ..... as it should ????
Any ideas on where to start??
cali-bra
by Mark1 » Sat Jan 26, 2008 12:07 am
Hello and welcome.
Get the alternator checked, had this happen ov a car in the past and it needed a new one.
by Calibra_Mike » Sat Jan 26, 2008 11:51 am
^as above...
Could be the alternator or something with the charging circuit... Might also be worht getting the battery checked somewhere like ATS to make sure its still up to the job, sometimes the battery cells break down and stop it from charging up properly...
by BazV6er » Wed Jan 30, 2008 12:25 am
i had this before xmas and mine turned out to be the alternator...
by cali-bra » Fri Feb 01, 2008 6:44 pm
Had the alternator checked today......turned out to be the faulty rectifier in the alternator. hopfully this will fix the problem.
cali-bra
by cali-bra » Fri Feb 08, 2008 9:33 pm
Alternator back in .................problem sloved :D . Thanks for the advice. Next job sump gaskets at the w/end :? cant wait!
cali-bra
