hid's gone!
hid's gone!
hi lads,have my nct sat(irish mot)and both balasts in my hids have failed me=[ have second hand head lights arriving tomorrow night and need to know how to take the hids out and go back to factory lighting!!
paudie
paudie wrote:is that it!!what does the silver box for that is located just behind the headlight??is that part of the HID kit?
That's the ballast/ignitor and part of the HID kit, to go back to standard lighting follow my first post. You can remove the rest of the HID kit later.
paudie
nearly have the kit out,just wondering 2things. 1-i presume the yellow wire is for the headlight bulb but can some one conferm this for me as i wont have the bulb untill tomorrow and 2- theres a black wire that is part of the kit attached to the back of the headlight.i cant get the of the kit out because it looks like the black wire is soldered on.can i just cut this wire off or is it needed for something??
paudie
paudie wrote:nearly have the kit out,just wondering 2things. 1-i presume the yellow wire is for the headlight bulb but can some one conferm this for me as i wont have the bulb untill tomorrow and 2- theres a black wire that is part of the kit attached to the back of the headlight.i cant get the of the kit out because it looks like the black wire is soldered on.can i just cut this wire off or is it needed for something??
Yellow wire is live to the bulb, where is the black wire soldered to ?
paudie wrote:got everything sorted with the head lights,thanks lads! my right hand head light is now higer than left (failed nct,left side fine) how do i adjust the beem down to match the left side??
Use a 13mm spanner on the part marked with a arrow
Users browsing this forum: Majestic-12 [Bot] and 19 guests
