Help pse?Brake Lights flash with Indicators.
Help Pse, my 93 calibra kept blowing a fuse when indicating & the fuse on the alarm, so only 1 side will flash, Ive had to put more amp fuses in but this is wrong I know, also now one side is duller then the other when the alrm is activated & while I indicate my brake lights flash with indicators??any Ideas pse tnx.
andym1fjg
check the bulb holders in the rear lights they might be corroded
BazV6er wrote:or a bad earth somewhere .
What Baz said, irratic behaviour in a bulb cluster is nearly always a bad earth somewhere. To prove it, have the bulbs flashing and temp' hold a wire onto the earth side of the bulb connection and earth the other end to the body, this should prove if it is indeed an earth problem.
