Odd behaviour from lights
by Petew » Sat Feb 23, 2008 6:33 pm
Hi all,
My rear lights are doing my nut in!
Problem 1:
When I brake, the right hand side brake and rear light come on at the same time but there is nothing from the left hand side.
Problem 2:
When the lights are turned on (at night) the brake lights are illuminated permanaently.
Any help greatly appreciated!
Pete
Petew
by v6 steve » Sat Feb 23, 2008 6:52 pm
Sounds like a bad earth
by Mark1 » Sat Feb 23, 2008 7:00 pm
Yep mines like that ............................I must fix it
Club Treasurer
Club Treasurer
by Petew » Sat Feb 23, 2008 7:48 pm
How is a bad earth resolved?
Pete
Petew
by cally8valver » Sat Feb 23, 2008 7:55 pm
sound slike a bad earth or corroision in rear lights block clean all terminals in block connector to rear lights then try
cally8valver
by matty0785 » Sat Feb 23, 2008 8:15 pm
bad earth by the sounds of it
find the earth wire on the rear lights wiring loom cut away some of the sheath and conect another bit of wire to the loom and touch it to good clean metal
by Petew » Sat Feb 23, 2008 8:27 pm
Cheers for all the help.
Is re earthing it an easy job to do or is best getting a pro to do it?
If so, how much hard earned cash will I be parting with this time?
Pete
Petew
by v6 steve » Sat Feb 23, 2008 8:30 pm
it could be a 2min job or an all day one just depends if you find the bad bit or not good luck with the search
by ROG » Sat Feb 23, 2008 9:53 pm
Have you checked there the right bulbs and there in the right way round? put in the wrong way they can cause problems like this
ROG
by Petew » Sun Feb 24, 2008 1:06 pm
Thats an interesting one. How can I tell if they are wrong? Pretty sure the bulbs are right, but I suppose I could have put the wrong holders in the wrong place.
Anyone know the right sequence?
Petew
