Heater
Heater
by cal » Thu Mar 06, 2008 5:38 pm
told you the questions would be coming thick and fast.
the heat fan doesnt seen to work , checked the fuse and its ok.....any ideas what to check next ?
chris
cal
by Fraz » Thu Mar 06, 2008 6:06 pm
give the fan a thump ..might just be stuck
by tazz666 » Thu Mar 06, 2008 9:24 pm
or it might be the resister which is needing replaced, i have a spare and a fan
tazz666
by cal » Thu Mar 06, 2008 10:27 pm
tazz666 wrote:or it might be the resister which is needing replaced, i have a spare and a fan
cheers chaps.
where is the resistor? is it on the fan itself?
keep hold of the fan , i may just need it.
chris
cal
by tazz666 » Thu Mar 06, 2008 11:23 pm
yes mate it is on the fan
tazz666
by cornishtaz » Thu Mar 06, 2008 11:40 pm
Does it work on any speed, if the resistor has gone then it'll only work on speed 4(this bypsses the resistor). If it's not working at all could be motor or switch( never known one to go)
cornishtaz
by cal » Fri Mar 07, 2008 8:39 am
these is nothing on any speed , i will report back this afternoon when i have had a closer look at it.
cal
by cal » Fri Mar 07, 2008 4:26 pm
all sorted , just a loose connector block, gave it a quick prod and it span into life.
cal
Users browsing this forum: Bing [Bot] and 36 guests
