DESPERATE!!!!!!!!!! HEEELLLPPPP
by markybrisca » Sun Mar 23, 2008 12:38 pm
Ok, finished delocking the cally with some vectra doorhandles, removed locks and taped up microswitches, problem is I caught one of the switches and car now thinks it is deadlocked and alarm keeps going off every time I open a door. Tried to press again but wont unlock/turn off alarm, what am I doing wrong? Got alarm module in footwell, which wire needs positive/negative pulse to turn off the alarm and turn off deadlocks????? Supposed to be going out in car tomorrow, no chance unless I can sort this problem out tho!!!! Someone pleeeaaassseee help meee, driving me mad!!!!! Thanks guys Mark.
markybrisca
by BazV6er » Sun Mar 23, 2008 2:58 pm
i pulled the microswitches out of the holders and taped up the holders and it worked great.
by markybrisca » Sun Mar 23, 2008 4:42 pm
If I ground unlock wire on microswitch, will it turn off standard security alarm/deadlocks?
markybrisca
by trev150 » Sun Mar 23, 2008 6:35 pm
Have you read the How 2 Guide on this site?
by markybrisca » Sun Mar 23, 2008 9:34 pm
Right, nearly there, looks like I have damaged the locking relay. Am I right in thinking the lock/unlock wires should be live and the alarm will pulse them with a negative pulse to lock/unlock the doors. If so I can take 2xlive feeds to each of lock/unlock and all will be good. This means door motors will be working as slave instead of in factory system through locking relay. I have disconnected all standard alarm multiplug and fitted complete system which has turned into an epic. AND ALL BECAUSE I DIDNT WANT DOOR HANDLES ON MY CALLY!!!!!!!!
markybrisca
by trev150 » Sun Mar 23, 2008 9:48 pm
Door handles or door locks?
by big_gordy » Mon Mar 24, 2008 4:49 pm
ahhh but there is a way to get into the car if the battery goes dead! hehe
by big_gordy » Mon Mar 24, 2008 4:50 pm
no locks= no srewdriver to the door = less damage :-)
by trev150 » Mon Mar 24, 2008 6:50 pm
Apparently If you use your screwdriver to force the handle out of the door you can gain entry. Although you will leave a massive hole i doubt that the car thief is bothered about that.
Anyway i wouldn't of put a Calibra high up in the at risk stakes, what about all those modern Astra Turbo's waiting to be stolen?
by Fraz » Mon Mar 24, 2008 6:54 pm
why bother with the lock...any car just needs the window put in
by jonboy78 » Mon Mar 24, 2008 7:20 pm
Fraz wrote:why bother with the lock...any car just needs the window put in
Well said! The car could be locked up to the hilt with allsorts but until they make brick-proof glass, its irrelevant.
jonboy78
by big_gordy » Mon Mar 24, 2008 8:14 pm
very true lads! lol
by trev150 » Mon Mar 24, 2008 9:58 pm
jonboy78 wrote:Until they make brick-proof glass, its irrelevant.
They do, it just costs loads and is unsightly with all the wire reinforcement in it.
by Phantom » Tue Mar 25, 2008 12:55 pm
actually if your windows have after market tint film applied to them they'll be pretty tough to get thorugh
de-locked handles look better in my opinion and you can colour code them to your car, and if the battery goes dead there's always the boot
by big_gordy » Wed Mar 26, 2008 12:46 am
well i learnd the hard way...lol
i have no boot lock and de locked handles and the battery went dead so needed to call mr AA man out to get it open
so i will now be tacking a feed from the battery and putting it some where i can get access to with jump leads if this EVER happens again.....lol
