Indicator Relay keeps blowing
Help pse my previous post was why I heard a noise from fuse box no indicators....changed relay all works fine for about a day then goes again...£9 a time, dont know if related but drivers side back & front are very dim..thanks..
andym1fjg
Sounds like a bad eath, check the holders and the contacts and give them a bit of a clean up.
Tnx for info shall check it tmoz,I gotto admit something else thou...b4 all would be fine for a little while then would blow fuses, well i didnt have a 10a at that time so stuck just a slightly larger fuse in...so maybe the current trying to blow a fuse dont now so takes it out on the flasher unit ..anyway the main thin gotta get to the root of prob so will check contacts etc..tnx for infos...
andym1fjg
