hi all some help needed please. ecu fault codes, on v6
hi ive just brought a v6 and very very surprised how much faster it is than my redtop.any way,i did a paper clip test just to see if it had any logged faults and it has.they are
12 (normal as engine was off)
14 Coolant temperature sensor - voltage low
31 No engine RPM signal, Engine not running, (Crankshaft Sensor - No Signal)
im stuck on how to fix the number 14 and the heaters were only blowing cold air and the temp on dash didnt go over 90 all day.
also (this is a strange one) after it flashed the number 14 code it then did a little pause(not as long as it does when its moving to the next code)and flashed 5 times?.anyone know what it could be.
cheers
cheers
blue redtop
