Misfiring badly
Misfiring badly
Back again!!
Had my car tested after a year on SORN. Failed on emissions, mainly, but came away from the garage misfiring badly, with crap power.
Another garage diagnosed a faulty coil pack, so I bought a new one. Unfortunately this didn't sort the problem.
Had the ECU tested and this is fine. I remember the MOT tester saying that the lambda sensor was fine and he thought the CAT might need replacing as the emissions were so high.
I now need some help on what to do next as this is beginning to cost serious moola with no solution.
All help greatly appreciated, as per usual.
Cheers, Neil.
Cheers, Neil.
buzzaldrin
I read a thread this morning that mentioned the ignition amplifier, and will relay that info to my mechanic, so thanks for that.
Does anyone know why the coil pack would show faulty if any of the problems mentioned were correct? Cos the mechanic was quick to diagnose the problem at the coil and not at the end of the leads.
buzzaldrin
The ignition amplifier will sow a fault on the coil pack as 2 of the leads wont be sparking iirc the amp sends signals in pairs to 2 coil nodes when damaged 2 of these signals dont get through allowing the car to run but drive like a bag of s***e.
had the same problem replaced the coil only to find no difference. Vauxhall will probably tell your mechanic there is no amplifier on the coil pack cause they are retards.
Tim2001
