ABS, reverse lights and high beam....
by Joker » Wed Jul 16, 2008 9:59 pm
3 questions.... :shock:
ABS
I had to lock-up the other day in my calibra to avoid a crash-and-burn happening, however my abs didn't work! Instead i have flat spots on all 4 tires any idea why the abs never kicked in? I have checked my fuses and none are blown.
Reverse Lights
My reverse lights work when they want to. I'd say 2 out of 3 times they DON'T work, I've pulled the clip out of the gearbox and cleaned it and put it back but still no good.
High Beam
Also my O/S high beam doesn't work so removed both bulbs and switched them over, still didn't work with another bulb, and the bulb i suspected broken didn't work in the N/S. That means that both the connection and the bulb didn't work though the bulb doesn't look broken upon inspection..very puzzled any ideas?
Joker
Joker
by DC 12v » Thu Jul 17, 2008 10:23 am
Check the fuses for highbeam.
I blew all of my light fuses out the other day while tinkering..
DC 12v
by Joker » Thu Jul 17, 2008 2:24 pm
no abs light on the dash no... I'll try earthing the switch out and checking fuses again.
Joker
Joker
by neilht » Thu Jul 17, 2008 3:05 pm
neilht
by pr0xZen » Sat Aug 02, 2008 1:48 am
Regarding reverse lights - any corresponding issues with Fuel computer and/or it's backlight?
pr0xZen
by Joker » Sat Aug 02, 2008 12:39 pm
pr0xZen wrote:Regarding reverse lights - any corresponding issues with Fuel computer and/or it's backlight?
come again?
I'll take the dash out and have a look see if there is a bulb in there, There are signs of attack with the screwdriver around the dash lol. Will take alook and get back 2 you. If the light has been removed what will that mean? other than it must have been on, but does that mean its foobered?
Joker
Joker
by Calibra_Mike » Sat Aug 02, 2008 5:04 pm
ABS could be down to a few things, Bulb, Sensors, fuses etc... check the bulb first, I had a problem with this and it turned out to be a crack in the track on the back of the dash circuit bit... bit of solder later and it was working again...
by Joker » Sat Aug 02, 2008 5:29 pm
but i no my abs doesn't actually work, on finding a blown bulb just tells me what i already no, I will check tomorrow and change it if necessary, all the fuses have been checked so they aint gone, all 4 cogs on the wheels are all in one peice also....
Joker
Joker
by Calibra_Mike » Sat Aug 02, 2008 5:39 pm
The bulb is part of the circuit IIRC so with out it, its not gonna work...
by Joker » Sat Aug 02, 2008 7:12 pm
what so if the bulb blows, the abs unit just won't work? never new that.
Joker
Joker
by Calibra_Mike » Sun Aug 03, 2008 9:28 am
Thats what I think I was told when I had the problem... pretty sure of it... someone will back that up or not lol :D
